Compression Tank Problem
Servicewiz_3
Servicewiz_3 Member Posts: 69
I have a very long ongoing problem with 4 different compression tanks on 4 separate zones.Al the tanks are showing the same symptoms.Eratic water levels.There is an air compressor set at 200 PSI that is piped out to the top of the 4 tanks.Is this correct?The building is 25 stories high and the mechanical room (containing some of the same piping and zones is located a floor above that.Any help is greatly appreciated!!!!!!!!!!!!
Servicewiz
