convectors
joe_61
Member Posts: 21
Replacing a convector element, hot water 3 pass coil 4ft long x6" wide copper coil aluminum. Bought new one from supply house, they came through in steel. Supply house says they are the same, btu's etc. would this be ok
copper vs. steel
if btu rating is same it should be ok. usually not good to mix types of radiation on system ie : never cast iron w/ steel or copper but steel & copper may not be a problem because they cool at similar rate as opposes to cast iron holding heat much longer because of different mass.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 69 Pipe Deterioration
- 949 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
