hey ME
Mark Eatherton
Member Posts: 5,852
And I see nothing that would cause it to have ghost flow.
I thought you'd determined the reason for the heat flow was a wiring issue.
What is your question?
ME
ME
hey ME
i don't have paint on this machine, so i hope this will do. and, i can't recall the exact order/locations of the mono supply/returns, or where they literally reversed the direction of the monos, but this is the basic layout0 -
in part, the wiring issue;
and that's solved. but as you mentioned in your other post, the check placement on the 1" line vs the header would've solved the ghost problem. because, when i spent some time there watching the system, that 3/4" line/pump is almost constantly on due to very poor insulation, lots of glass, a leaky glass paned door, and with the stat 1' away from the door. so, the 3/4" return is constantly pushing hot water into the header, right next to the 1" return0 -
I really think Mr. Vickers
you should get someone in there that knows what they`re doing.
Even by reading Tony`s postings in the other threads, you don`t!
Dave0 -
but if you knew the details
from today's excursion with a weil rep, your post would expose you as the one who doesn't know what they're talking about. and nor does tony regarding that specific system vs a true primary/secondary
and that m'man, was shineola0
- 86K THE MAIN WALL
- 52 Biomass
- 421 Carbon Monoxide Awareness
- 81 Chimneys & Flues
- 5.3K Gas Heating
- 96 Geothermal
- 154 Indoor-Air Quality
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 893 Plumbing
- 5.9K Radiant Heating
- 379 Solar
- 14.7K Strictly Steam
- 52 Water Quality
- 41 Industry Classes
