indirect
Jim Franklin
Member Posts: 170
Can you pump from the from the bottom of the boiler instead? Or, is there an aquastat in series when the indirect is firing to prevent making steam?
indirect water heater
is it ok to use an air vent on a weil mcclain gold plus 80 , when it is heated off of a steam boiler and the supply pipe from the boiler goes above the water line of the boiler?ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0 -
great question
if it were me I would use the air vent to get the intial air out then close it off. I would check w/ weil about the application as to the appropriateness of using that tank vs. a coil style....kpc0 -
I wouldn't
use the air eliminator if the indirect is connected directly to the steam boiler . Any air introduced at the high point and the water will siphon back to the boiler .
Dan explains how to pipe a zone from a steam boiler in the link below . Substitute the indirect for the zone of heat and you'll be good to go .
http://www.heatinghelp.com/newsletter.cfm?Id=290 -
indirect
i went to the job the other day and the tank was completely depleted of hot water. it was like there was no circulation... i checked the pump and that was okASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
