Steam Air Valve
Sandra_5
Member Posts: 4
I have one-pipe steam radiators. I know I have to replace the air valve on the side of two of the units. Does anyone have a recommendation of which valve would be best to buy?
Gorton Air Valves are the best. You have to know what size you want though.
Vari-Valve is also good. You can adjust the amount of air you want to exit out of the vent.0 -
Here's the blurb on Vari valves
http://www.heat-timer.com/literature/VariV056082C.pdf
http://www.heat-timer.com/?page=varivalve
They are adjustable but can have a tendency to "spit" water in some circumstances.
- Rod0
