water heater
Paul S_3
Member Posts: 1,291
the air vent on my weil mcclain gold plus 80 sucks in air ....is that normal? i have some problems with my hot water? its heated off of a steam boiler with a mixing valve
ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
347-692-4777
ASMHVACNYC.COM
Paul this is not normal. It is doing as it is designed but it should not suck in air when it is running. The hard part of using this tank with a steam system is maintaining the water to the top as it is above the water lind of the boiler , well I am guessing it is. WHere are you and what is your issue you are having with hot water. Pics of piping may help clear up whats going on.Cost is what you spend , value is what you get.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating0
