Pipe insulation
David Nadle
Member Posts: 624
What state? Commercial or residential?
Pipe insulation.
Is everyone insulating their pipes as per International Energy Conservation Code?
I had an inspector fail a contractor because his boiler pipe had no insulation on it. Contractor did not have insulation in quote. Customer had in job spec that everthing be done as per local code.
Now what.
Pays to keep up with the code.
NJ
In NJ com. & res. From what i read in the book. Should be any state that adopted the energy conservation code0 -
insulation
NY too- in my area at least for the past few years. if it's well done, makes for cold basements0
- 167 Indoor-Air Quality
