Ultra E-02 fault code
Wayco Wayne_2
Member Posts: 2,479
about an Ultra failing regularly on an E-02 code. I've never worked on them before. Any help would be appreciated. WW
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=255&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Wayne I have...
had this happen 2 times. Could be a few things. Clean up the ignighter first and the chamber. If it is a 155 look to see if the refractory plate is attached properly. I had one where the screws that hold it on we loose because the tabs that lock it in were not bent over. How old is the install?0 -
2 years old
I think. Maybe 3. WW
In control supplement
ON Page 20 and 25 if you don't happen to have
http://weil-mclain.com/downloads/literature/ultragas/ultracontrolsupp.pdf0
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 69 Pipe Deterioration
- 951 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
