LP gas meter
Simply Rad_2
Member Posts: 171
I have a conscience client that asked if I could find a gas metering device for LP. I have only personally seen natural gas meters... But maybe I can just use one of those meters.
If not has someone used another type of meter?
Thanks Jeffrey
Thanks Jeffrey
http://www.plumbingsupply.com/gas.html
Get the temp. compensated meter and read as normal then multiply x 0.64 should put you very close.
HTH,0
