cast iron boiler with bad female threads for vent .
I have a cast iron radiator with bad female threads for vent valve. I do not think the threads can be fixed with a tapp should I drill and tapp next size.
  • Larry Simon
    Larry Simon Member Posts: 2
    bad threads
  • Charlie from wmass
    Charlie from wmass Member Posts: 4,422
    Depends on your level of skill with such things. It has been done but also I have been on calls were the home owner tried to tap the threads after drilling out to the next size up and they cracked the radiator.
    cell # 413-841-6726
    https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating
  • Kool Rod
    Kool Rod Member Posts: 175
    I think I'd consider a Helicoil before I'd go to a bigger tap size. They make kits for some individual sizes and which comes with a drill, a Helicoil tap, an installation tool and usually half dozen helicoils in that size.
    I know they have pipe threads sizes as I had to do a pipe thread in a Caterpillar head a few years ago. Look on the internet under something like: "Helicoil kit 3/4 pipe thread" and see what you can find. You might inquire at a local plumbing supply house.
    Since the pipe threads are tapered it would seem to me that you could chase them out a bit with a pipe tap to clean them out.
    JH3550
    Youe can try chasing the threads their may be enough meat left to seal a vent. I have used heli coils but never on a tapered thread. If you do tap it out to 1/4" be careful and take it slow.
    cell # 413-841-6726
