Heliodyne 'Solar Hot Water Module'
Mike Dunn
Member Posts: 189
Please do not route domestic water through the heating system. You know "Can open, worms everywhere" kind of thing. Instead use the Heliodyne module.
Mike
Mike
Heliodyne Solar Hot Water Module
I have a client that wants me to help him install a solar thermal system that will combine space heating (hydronic baseboards) and DHW. I do mostly PV, but did a number of SDHW system back in the 80's. He will be buying equipment from Heliodyne, including a device they call a 'solar hot water module'. As far as I can tell it is basically a heat exchanger that isolates the DHW from the space heating loops. Anybody have any experience with these systems? Is there any reason that potable water could not be run through heating loop if everything is copper? Thanks for your help0 -
The only Helio- products i have used have been on solar heated pool systems. And mabey a bad batch but i had nothing but annoying issues with that product. Mind you it wasn't same product, just the make.0 -
Heliopak
comes in different sizes, what part of the country is the install, solar and baseboard usually is not an option if you want to make it cost effective. the ones we use for Closed loop systems isolate the solar loop from the potable water side by way of the external exchanger on the Heliopak and a cirl. for each side0
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 69 Pipe Deterioration
- 951 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
