pros opion
dave_146
dave_146 Member Posts: 1
any pros cons to wireing a circulator to constant voltage the system is a basic res. boiler one zone. my thought in doing this is to extract all the btus out of the boiler instead of the all that hot water just sitting in the boiler after the stat is satisfied. my only concern is I have noticed at times the boiler temp will drop below 70 degrees between cycles. causing a (cold start ? )
