Bad smell
Rusty Powers
Member Posts: 30
I'd look for a floor drain, laundry or sink p-trap that has dried out...
Could be a dead mouse also.
My black lab is amazing for mystery stench detection.
Bad smell
I walked into a ladys house today, and agreed with her assessment that it smelled yucky near the boiler. Its a closed loop electric boiler with 3 zones on pumps. It heats fine, but she says the pressure gets too high from time to time, plus theres the smell issue. I drained some water into my hand, and it didnt seem to smell bad. Then I vented air out of the expansion tank, to see if it was waterlogged, and air did come out, but it smelled VERY bad - like a combination of sewer and sulphur.
There is no smell from the water at any of the plumbing fixtures, its city water. So all I can think to do is to bid replacing the fill valve and expansion tank. Am I missing something?
Your black lab is also
inaudibly flatulent too, I have heard.
That come in handy sometimes!
Like Rusty said, it might be a floor drain. The shool system I use to wor for woud occasionally have a smell in the kitchens or mechanical rooms because the custodians forgot to add water to the drains (they had traps). If you find a drain and it goes directly outside, perhaps there's something dead in it.0 -
Not sewer gas
I've had a lot of experience with that. (The worst one was a dead 'possum in the crawl under the bathroom, swarming with maggots) The boiler is in the garage, no plumbing nearby, and the smell is definitely strongest at the boiler.0 -
check
Check for pitted contactor sticking couple, with a bad limit.
- 167 Indoor-Air Quality
