No Heat from Panel Radiator
Paul MacDougall
Member Posts: 36
I recently installed a Radson Panel Radiator, to replace a free standing cast iron radiator during a bathroom remodel. The radiator worked for at least five days during cold weather, then all of a sudden, no heat. The existing system was an old gravity system converted to forced hot water with pumps in the return, with a 3'' main and 1'' feeds off the top which I adapted onto. I spoke with the rep and said that this particular set up wouldnt effect the radiator and the water should pull through, which it did. Now there is no heat unless I continue to bleed water from the radiator. Will contact the rep again tomm. Looking for any ideas. I apoligize in advance for spelling and grammar.
sounds like...
a piping issue. The head pressure on the rad are much higher than those of a wide open CI rad.0 -
Could be "stuff" in the passages of the rad. Does it have a TRV or a bypass? old gravity systems can be dirty beasts inside.Cost is what you spend , value is what you get.
cell # 413-841-6726
It has a by-pass valve and we have removed the TRV to get full flow.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 69 Pipe Deterioration
- 951 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
