Glowcore GB607--replace or keep
Tim Weaver
Member Posts: 49
We have a Glowcore GB607 I installed 18 yrs ago. Its still running but I hear that the coil is subject to pin-hole failure and that I should replace it ASAP. What's anyone's
experience w/ this coil. Is it worth replacing as a part--I don't know if its available anymore or should I go with a Weil-Mclain CGs series since this is all baseboard heat
Thanks, Ray
Thanks, Ray
replace
replace it but I would wait till it fails. they are no longer made and parts are very sparse. Triangle makes a nice install. I would have put one in when my Glowcore heatexchanger failed last year the day after Christmas but I put in Munchkin because i did not know of the Triange. If it has been running 18 years it's a keeper I do not know of any other that lasted that long.0 -
You are on....
borrowed time. Start planning now to replace it as soon as heating season is done.
Yo can do better that the W-M CGs. Triagle tube is a good product IF you can find one... Embassy has a great line of boilers BMS, AXIA and the new Onex.0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 123 Geothermal
