Munchkin making Sound
Steve M_2
Steve M_2 Member Posts: 121
Sounds like it could be a bad swirl plate to me especially if it's been gradually getting worse. I'd have one on hand because the best way to check it is to remove the burner assembly, gas valve and inducer all in one piece. It's a 20-30 repair that way. Trying to do it in place is next to impossible. It's probably sucking in exhaust gases which in turn will degrade the swirl plate.
