Fuel Tank Lines -- Steel or Copper
Erich_3
Member Posts: 135
Which type of fuel oil line is best, steel, brass or copper, for an inside oil tank?
fuel oil lines
in mass code calls for copper lines with flare fittings0 -
To go one step further, a copper line inside a coninuous plastic sleeve (with flare fittings)
2 Steps further...
[orange] Plastic jacketed copper oil tubing (Pro-Tec, Petro Guard, etc.) in [blue] continuous plastic sleeve (ENT or "smurf tube") -- with flare fittings of course.
Black iron or brass pipe could be used for short rigid connections between sludge pots or primary filters and secondary filters, or between tiger loops and filters. Don't forget the firematic valve(s) too.0
- 86.8K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 104 Geothermal
- 69 Pipe Deterioration
- 951 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
