Consulting for Consumers - Alan R. Mercurio
What is consulting for consumers? It's an area I have created in our community over at Oil Tech Talk just for you, the consumer. You’ll find links to resources that will help to further your knowledge and awareness of the products and services available in the oil heating industry, allowing you to make educated and informed decisions that will benefit both you and our environment. And should you need guidance, don’t worry; I’m here for you!
I’m Alan R. Mercurio, your friend in the industry and the host of Oil Tech Talk. I have been in the residential oil heating business for more than 20 years, and I’ve enjoyed every day. I have taught thousand of technicians and continue to do so, and I’m here for you.
Companies such as R.W. Beckett, the largest burner manufacturer in the United States, Honeywell Corporation, and other have used my services. I’m involved with key organizations within the oil heating industry:
<a href="http://www.bnl.gov/est/erd/default.asp">(BNL) Brookhaven National Laboratory</a>
<a href="http://www.hudsonvalleyoilheat.com/index.mv?screen=home">(HVOC) Hudson Valley Oil Heat Council</a>
<a href="http://www.naohsm.org/">(NAOHSM) National Association of Oil Heating Service Managers</a>
<a href="http://www.nfpa.org/index.asp?cookie%5Ftest=1">(NFPA) National Fire Protection Association</a>
<a href="http://www.noraed.org/">(NORA) National Oilheat Research Alliance – Education Center</a>
<a href="http://www.oilheatcares.com/">(OHC) Oil Heat Cares</a>
So when you need a bit of advice, or just some guidance, please consider my years of experience and the passion I have for this industry, and for consumers like you. I’m here to serve. You’ll find my rates reasonable and I’ll always be there for you.
Thanks for your consideration.
<a href="http://www.oiltechtalk.com/thankyou.shtml">Click here for Consulting Services</a>
Your friend in the industry,
Alan R. Mercurio
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=408&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • Wayne_29
    Wayne_29 Member Posts: 50
    That's a fantastic idea!
    Alan, will it be a "Do It Yourself" consulting service? I am glad you are feeling up to working as a consultant!
    Rick
  • Alan R. Mercurio_3
    Alan R. Mercurio_3 Member Posts: 1,624
    Hi Rick, with the exception of things a consumer can do safely by themselves, no this will not be about consulting them on performing repairs and/or installations on their own. If anything I’ll share and educate consumers as to why there are things they just should not attempt doing on their own.
    Alan R. Mercurio
