Water Heater With Electric Plug from Factory
Erich_3
Member Posts: 135
Is a domestic water heater (DWH) with an electric cord with a standard 120 volt 3 prong plug an approved method of connecting to the electric supply. I was thinking that BX or conduit was the correct method.
Maybe...
... A small 15amp unit in a cabnet. In a boiler room depends on local codes.....There was an error rendering this rich post.
On Demand Toyotomi
It is an on demand oil fired Toyotomi. Maximum 120 watts usage. Does it need to be connected to an emergency shut off switch? New York state is the location.0 -
Electrical
Should be wired on the load side of remote emergancy switch, single circirt with boiler. A service switch on unit. Thin wall to unit. And depends on location ,BX to wire unit.There was an error rendering this rich post.
Which Code?
Can someone point me towards the applicable code? Thanks.0 -
Code Book
Check your local library for the New York electrical code book. Then call your town and see if they supersede the NY code.There was an error rendering this rich post.
