White Rodgers Zone Valve Replacement
That's not a White Rodgers valve. Its a Honeywell and a heating pro can get replacment motor for the unit.
  • JohnL
    JohnL Member Posts: 38
    Zone Valve Replacement Question
    I have a 20 year old White Rodgers Zone Valve that has died (13A01 or 13A03). No one seems to have the replacement head for this model so I think I want to cut the zone valve out and replace. Should I sweat a union to the pipe so If the valve fails I can remove without cutting the pipe?
    I see that some Taco models have a replacement head. Are these any good? Do some last longer than others?
  • JohnL
    Thank You
    Thanks for the info. It was a Honeywell head and I replaced with the 8043 head. Thank you for your assistance.
  • JK_3
    JK_3 Member Posts: 240
    Hi john
    You should have sent me the pics and I would have told you I stock the replacement heads for the honeywells on my trucks. Is this one that i replaced for you? I hope everything is working ok now.
