Effikal flue damper
check out this <A HREF="http://forums.invision.net/Thread.cfm?CFApp=2&Thread_ID=62129&mc=1"> thread </A>, perhaps something here applies?<BR><BR>Dave
  • Al Nardizzi_3
    Al Nardizzi_3 Member Posts: 1
    Effikal Flue Damper
    Intermittent problem with home heating system,thermostat is calling for heat but the boiler doesn't turn on. I just tapped the flue hood where the Effikal flue damper is installed and the system fired right up. Anyone ever deal with this type of intermittent problem? Should I replace the damper or is the problem elsewhere in the controls?
  • Charlie from wmass
    Charlie from wmass Member Posts: 4,408
    The Smith boiler I had the issues with had an effikael damper. I have it locked open until I see if there is a better option. Electrical units and flue gases do not go well together. waiting for the Wallies to hash out what the options are myself.
    cell # 413-841-6726
    https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating
  • MikeyB
    MikeyB Member Posts: 696
    vent damper
    Al, check Effikal's web site, Dan H had posted a re-call notice from Effikal's web site a couple of month's back
  • Dale
    Dale Member Posts: 1,317
    Other thing
    Tapping on the flue hood could have caused the spill switch to reset, I think this would have made the damper close first then reopen. Sticking dampers are a VERY commom problem, althouth usually first call of the season. If you tap the damper and the ignition starts the prove open switch or it's lever cam isn't closing correctly giving a start circuit to the electronics. If it's under warranty get a new damper, if not the fuel savings payback is not usually there for a new damper and labor so have it removed. DO NOT wire it open, too risky, just replace with vent pipe.
  • Ken D.
    Ken D. Member Posts: 836
    Effikel
    I received a recall notice on Effikel dampers. See you supplier or factory rep about it.
  • The Boiler Dr.
    The Boiler Dr. Member Posts: 163
    I have had 3 this year
    Broken drive shafts on 1-8" and 2-10" units
    Why would they use a plastic drive shaft on a flue damper?
    I noticed the replacement field units have metal shafts.
