heatmaker
tim smith
Member Posts: 2,886
plenty of them and want them gone someday.
heatmaker boiler
does anyone have wiring diagrams for the old style heatmaker hw series boiler?(without the circuit board) thanks...0 -
whats the problem ? -- do you have a model # i think i still have a print at my shop --they used to be inside the cover of the units0 -
heatmaker
theres no problem...i just cant find the schematic for the older model hw series (without the circuit board) on the internet...i dont have a model number0 -
i'll check in my desk in the AM and see if i still have it0 -
thanks0 -
We have them
Give us a call at 800-900-9276 with the serial number, and we'll get you the wiring diagrams. Or email me (my email address is jmishouatlaarsdotcom.....use the @ instead of 'at' and the . instead of 'dot'....bots get the email address if I write it correctly.)
Joannie
Laars Heating Systems Company0 -
checked this mourning i only have a print with the board --0 -
Got Your Email
Hi, Paul.
I got your email this morning and sent you the one from 1988. Let me know if you did not receive it, or if you find a serial number, so I can zone in on the date more accurately.
Joannie0 -
heatmaker system
I have heatmaker system, which makes both the heat and hot water for my condo unit. The system probably needs a new heating coil and there is water in a cylinder tank. There might be more issues.
Is there an alternative to such a system. I would rather not have another heatmaker. I have approximately 2 feet to work with north to south and 50 inches to work with left to right.
Any sugestions, would be appreciated.
Thanks0 -
Burnham minuteman -is pretty close replacement check on their website0 -
RE: heatmaker replacement, maybe a Triangle tube Prestige
excellence boiler. This has built in heat exchanger for domestic hot water. You need to be pretty frugal on hot water useage to deal with output capacity but other than that great boiler, wall mount and condensing.0 -
Heatmaker Mark 2 furnace parts
Looking for used parts for my Heatmaker Mark 2 furnace. Please let me know if you have any. Need ASAP. Combustion chamber and Pump.0 -
used parts...
are going to be tough to find. Here is a link to new parts... http://www.parts4heating.com/Heatmaker-HW-M2-Series-Heating-System-Repair-Parts-s/5958.htm?searching=Y&sort=5&cat=5958&show=30&page=2
Where are you? Maybe try craigslist in your area.
Depending the state of the unit you may be better off getting a new boiler.0 -
Heatmaker parts
As of 3 or 4 yrs ago, you could get all Heatmaker parts from Laars.com because they brought Trianco out a few years ago.0 -
Laars Parts
As of about 3 weeks ago....
Laars sold us a "rebuild" kit... it had the heat exchanger, solution limit, pressure switch, air vent, and a coin vent. It was about $1500.0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
