sream riser(residential) copper vs. black pipe,is copper
Charlie from wmass
Member Posts: 4,409
Yes please search the forum as many posts cover this. also check the I&O manual as it probably says iron only in it.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating
cell # 413-841-6726
steam riser
recently a company installed a new steam boiler in a relatives house and used copper pipe for the riser(I know the correct way is black pipe with a swing joint)can anyone confirm that copper is accepted thru BOCA code? And has anyone seen a definite problem down the road with leakage at the soldered joints on the riser?
thanks for your input0
- 86.8K THE MAIN WALL
- 56 Biomass
- 108 Chimneys & Flues
- 5.6K Gas Heating
- 105 Geothermal
- 69 Pipe Deterioration
- 962 Plumbing
- 6.3K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 44 Industry Classes
