Weil McLaine steam boiler makes a banding noise
Can be a lot of things...
Pressure too high, wet steam, improper ventings, most importantly, got any pictures of the boiler and near pipings?
  • John_228
    John_228 Member Posts: 1
    Banging noise
    I have a Weil McLaine steam boiler that makes a banging thumping type noise when the system is cold or warm when the system is making steam there is no noise, I flush the boiler out with just plain water every summer but I feel that there is maybe a sludge build up in the boiler and this is causing the noise when the system is cold.Is there a way to clean out the boiler or use a chemical to flush it out. any help or ideas
    Thank You for your helpJohn
