tar paper before overpour
greenhead_2
Member Posts: 13
do I need anything on the wood floor before an 11/2 of concrete?
Not tar paper
Problems with odors may occur down the road. If the floor is above a finished space or basement, off the cuff I would say the wood should be covered with a plastic sheet of some kind to prevent water/cement from running through. I've never been involved in an application like that so I haven't had the opportunity to do any research on it. Someone on here may have or you could call RPA or see if you could get in touch with Siggy.0 -
Concrete on Wood
I lived in a house with a mudded bathroom floor over 125 years old. The wood underneath the concrete was in pristeen condition. There was nothing over it except for some metal lath. My guess is that the concrete seals the air out and thus any chance of rot.0 -
overpour
do hot use tar paper,ive done afew of these on jobs and in my own house, i used a reflective product on a few floors, alum foil on other floors,the last floor i did i painted the plywood with aluminum paint,i figured any thing to help reflect the heat upwards.
just the other day my son an i finally insulated under the kitchen floor,the one painted ,almost instantly the house got 10 degrees warmer,had been 60 all day,we got done and came upstairs big difference.
So now i need to go get more insulation for the other rooms,see bpost under concrete...............mike in hopkinton0 -
tar paper
we have done many jobs like this, you need some type of vapor barrier to prevent the plywood from soaking moisture from the concrete while it curing or you wind up w/ cracks. you can use tar paper,( I've never had problems w/ any odors) but it I find it easier to use 6 mill poly, you can easily find rolls up to 20' wide & 100' long. easy to cover just about an size room0 -
keep the wood from soaking
the water of convenience out of the concrete. 6 mil plastic works, a bit slippery to work on. Asphalt felt paper should also work if the temperatures are under 140F.
hrBob "hot rod" Rohr
Living the hydronic dream0
- 428 Carbon Monoxide Awareness
- 114 Geothermal
