24/7 Utility Shield
bill_42
bill_42 Member Posts: 2
I'd like to get some feedback on the 24/7 Utility Shield by Utility Managment Association if anyone has used or heard of it.
It's a two layered aluminum foil shield which is installed in your attic over your existing insulation. It can also be installed with radiant floor heat. I have a radiant system with staple up tubing and bubble foil insulation now. Is this product more efficient and is it installed the same way?
