Rheem Warm air furnace question
Mark_82
Member Posts: 11
Hello-I have a Rheem Warm air furnace-about 16 years old 5 years ago-I changed the heat exchanger and combustion chamber ( That was the only way i could get the Combustion chamber) it was an upgrade kit.. Anyway-all is fine--however-i removed the beckett burner assy to clean things up--and noticed that the combustion chamber had some small cracks-Not going through the chamber-but surface cracks--The chamber is in tact and looks good--clean white but with the small cracks--I'd like to change the chamber--Its easy enough--Where could i get a replacement chamber--The company i bought the kit from is no longer in business... Thanks so much for any help--The model number of the new kit is RXOH-AU24A--and i know for a fact i can get the chamber--because they told me after i upgrade with the kit- the combustion chamber can be ordered seperate..Thank you for any help... Mark
Wholesaler - parts house
Have you checked with a Rheem/ Ruud wholesaler?0 -
Go to Rheem's website and find the rep for your area. They would know who sells their equipment.
TimJust a guy running some pipes.0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
