oil lift pump
Hi folks. I encountered a 'Gotech SP 32-01' with no documentation. Its a reservoir and lift pump to bring the oil up from one floor down and subterranean. It is showing a code 6 which is generously translated from German as "leak". It has a grated bottom pan with a puddle so this isn't a vacuum leak. It this an open and adjust level case, or a fatal failure? Any Euro oilytechs out there?
- 80.9K THE MAIN WALL
- 2.5K A-C, Heat Pumps & Refrigeration
- 36 Biomass
- 394 Carbon Monoxide Awareness
- 2.6K Controls
- 1.4K Domestic Hot Water
- 3.7K Gas Heating
- 100 Geothermal
- 130 Indoor-Air Quality
- 2.3K Oil Heating
- 30 Pipe Deterioration
- 560 Plumbing
- 4.2K Radiant Heating
- 333 Solar
- 12.1K Strictly Steam
- 36 Water Quality
- 7 Industry Classes
- 7 Recall Announcements
