Friday Brain Teaser
Mark Custis
Member Posts: 537
with Mike.
Why do you want to remove it?
Friday Brain Teaser
Does anyone have any ideas as to what this is?
It is off the supply side of an old cast iron radiator in a home. It used to be a steam system but is now hot water.
Can this be removed?
See Attached Picutre*0 -
My guess
is an offset union type adapter with a built in debris cleaning port.
Now keep in mind I'm no steam expert but I did stay at a Holiday Inn Express last night.0 -
That Appears to be
A Dunham Adjustable Regulating Fitting, Type 196. Under the cap is (or was) an adjustable orifice style regulator.
Does this unit have heating problems?
- 86.8K THE MAIN WALL
- 56 Biomass
- 106 Chimneys & Flues
- 5.6K Gas Heating
- 104 Geothermal
- 69 Pipe Deterioration
- 952 Plumbing
- 6.3K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
