Heil heat pac
down below in Eugenes area.
Heil heat pac
Good Day, I have a 1988 Heil propane heat pac (heater/ac unit). The heat exchanger is cracked and the heating mechanic shut it down. Bad time to do that cause it's winter. Anyway, does anyown know where I can find a heat exchanger for Model #NRGF30DDB03, Serial #L882186518, part #522530? Thank you0 -
heil heat exchanger
it will be easier to replace the furnace rather thn just the heat exchanger0 -
Try Heil
At 20 years old retirement is in order.0
- 86K THE MAIN WALL
- 52 Biomass
- 421 Carbon Monoxide Awareness
- 81 Chimneys & Flues
- 5.3K Gas Heating
- 96 Geothermal
- 154 Indoor-Air Quality
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 893 Plumbing
- 5.9K Radiant Heating
- 379 Solar
- 14.7K Strictly Steam
- 52 Water Quality
- 41 Industry Classes
