Radiant pipe spacing and attachment
Nailed
Member Posts: 2
We have a Green Build affordable housing project that we are using a hanging system for the first time. The framing is on 24" centers and the heating system is at 12". We are using 1/2Pex. That is OK with the Pacific Northwest Winters but the contractor installed the pex on each side of the joist. So the spacing is really something like 3" then 21". Will the air space warm evenly with the odd spacing and will the fact that the pex is nailed to the joist and not the bottom of the floor be a problem? The joist was easy to attach to, should I have them change it?
radiant install
The first thing you should do is get the yellow pages a find a certified radiant installer.Have them do a heatloss and evaluate the job.There is not enough space here to tell you where this job is going wrong.0
- 86.7K THE MAIN WALL
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 939 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
