Heil heat pac
Timothy_3
Member Posts: 3
Good Day, I have a 1988 Heil propane heat pac (heater/ac unit). The heat exchanger is cracked and the heating mechanic shut it down. Bad time to do that cause it's winter. Anyway, do you know where I can find a heat exchanger for Model #NRGF30DDB03, Serial #L882186518, part #522530? Thank you
This is Eugenes area
but maybe I can help. First of all the mechanic that shut it down did not offer to find you a heat exchanger? He should be trying to help you do so.
I personally do not like replacing heat exchangers. That said is there any warranty on this? I prefer replacing the entire unit.
What is your location? Sometimes if you Google Heil Quaker and get there site they will list local dealers.
I will do a little investigating and see what I come up with.0 -
Looks like it's a 1988 model, 12th month (or week, but not likely).
Do your wallet a favor and get a new system if it is. Your energy savings will balance out the cost of the new system in a short time.0
