Steam form chimney
Billy_12
Member Posts: 25
Much thanks Fred. Happy holidays!
All of the sudden...
steam from chimney. I was plowing and looked up and STEAM!
I have a brand spankin new Burnham Megasteam (oil), and everything runs great. No loss of water. I mean, everything runs great, but steam up chimney means less steam for the rads. Could my draft be incorrect causing condensation? I have the baffles installed in boiler. I did searches but I don't seem to have similar symptoms.0 -
Chimney Steam
What was the outside temp? Keep in mind that burning a gallon of #2 fuel oil produces 1.18 gallons of water, all by itself. During low temps, that water vapor quickly condenses upon leaving the chimney. If your boiler is not loosing water, then ...0 -
It's 25 degrees out. That makes sense. So it's normal? Like I said, absolutely no other problems.0 -
Chimney Steam
Probably normal, when cold and humid outside. Also, a megasteam has a cooler stack temp because it is more efficient than earlier boilers. The cooler stack temp predisposes the flue gas to quick condensation.
If all else OK, no problem.0
- 86.8K THE MAIN WALL
- 56 Biomass
- 108 Chimneys & Flues
- 5.6K Gas Heating
- 105 Geothermal
- 69 Pipe Deterioration
- 954 Plumbing
- 6.3K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
