Hydro air HX?
Timco
Timco Member Posts: 3,040
Have a leak on a hydro-air HX that is right on the supply manifold. Want to just swap it as there is soo much corrosion & looks to be at least 2 bad spots. Are these sized by dimensions? Pretty large. 2' tall, 2' deep, 4' long or so. Any suggestions on brand / supplier, or should it be braised?
Tim
  • Brad White_191
    Brad White_191 Member Posts: 252
    Replacement coils
    Heatcraft is one, The Coil Company is another... there are a number of manufacturers that make stock coils that can also work. I use TSI (Rae Corp. out of Pryor, OK) for a lot of duct coils. They will do custom work. Beats repair for the cost and assurance..
    Hey, you and Joan coming east yet, what is the deal?
  • Timco
    Found a place in Middletown, but waiting to see if her son can find a job to rent it from us for a year or 2 while she ties up comittments at the U of U. We would also need to move some property here, but it does look like we are still into it...thanks for the advise on the coils.
    Tim
