Adding Water to a New Steam Boiler
Big Ed_4
Member Posts: 3,345
You now need to fix the leak in the other part of the system. More info from me, check my posts under " Dirty Water"...
I just converted from an old oil steam boiler (1936 era) to a new gas steam boiler, Utica PEG187C and a RUDD 40 Gal.hot water tank(see pictures below). I am happy with the performance of the new boiler It sure is a lot faster and pumps the steam very well. My question to the "Steamers" is, is it normal to have to add water to the boiler ~ once a week or the LWCO kicks in. The capacity of the boiler to the water line is 7gals.,to the LWCO is 4.4 gals. That means I lose ~2.6 gals.a week. Is this normal or am I spoiled from the old clunker I got rid of. I know I can have a automatic water replenisher installed but I don't know if thats the way to go.
Thanks for any help you suggest.
Paul0 -
I did not have any leaks before I replaced the old boiler and there is none in the new piping. I'm still at a dither where I'm loosing 2.4 gals.of water a week. Could it be possible I could loose that much water through the radiator valves ?
Paul0 -
BAD VALVES
IF THE AIR VALVES OR MAIN VENTS ARE BLOWING STEAM , YOU WILL LOOSE A TON OF WATER. OTHER POSSIBILITY....UNDERGROUND CONDENSATE RETURN ROTTED0
- 119 Chimneys & Flues
- 114 Geothermal
- 76 Pipe Deterioration
