Looking for modulating burner pressure controller...Boilerpro
Blackoakbob
Member Posts: 252
Check with www.omega.com, they have many, many ranges of 4-20 ma transducers. Best regards,
Controller for low pressure steam.
I have not been able to find a control to operate a modulating burner at appropriate low pressure for a typical steam space heating system......about 1 psi or less. Honeywell has dropped thier 0 to 135 OHm low pressure controls and has nothing to replace them. Johnson has nothing either. Honeywell's new 4-20 mA pressure control operates down to about 2 to 3 psi....so it is also not appropriate. Any ideas out there? We have ordered the burner with 4 to 20 mA input, since this is where most modern controls appear to be going.
Boilerpro
Boilerpro, Look at Heat-Timer control # MCA Elite modulating
steam pressure control. Does 4 -20 0-10vdc etc. Should work for you. Tim0
- 86K THE MAIN WALL
- 52 Biomass
- 421 Carbon Monoxide Awareness
- 81 Chimneys & Flues
- 5.3K Gas Heating
- 96 Geothermal
- 154 Indoor-Air Quality
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 893 Plumbing
- 5.9K Radiant Heating
- 379 Solar
- 14.7K Strictly Steam
- 52 Water Quality
- 41 Industry Classes
