Pump on return side- pics
Peter_26
Peter_26 Member Posts: 129
A couple of weeks ago I asked about having the pump on the return side and how should be installed on my new boiler. The picture is attached. The new boiler is a Smith Hot Water Boiler GV100 W-5 HSI Boiler. Let me know what you guys think. Another thing would be if a chimney liner is needed. The chimney is lined with a clay flue.
  • Brad White_191
    Brad White_191 Member Posts: 252
    When does the
    new boiler go in? I take it this is planning time and not too urgent.
    Also, where does the expansion tank connect? I am gathering that it is the small copper line in 100_1363.jpg. If so then you are pumping towards the expansion tank. There is sufficient opportunity on the suction side of your circulator to install one there unless you are going to wait for the new boiler install.
    Now, the larger piping looks like an old gravity HW system. You would benefit from a P/S arrangement or a bypass.
    The literature does say that it can be vented into a masonry chimney and clay tile is the least way you should go short of a new listed liner system. If in doubt, follow the manufacturer's literature.
  • Pedro_3
    Pedro_3 Member Posts: 9
    Hey Brad,
    No, the new boiler has not been installed yet. I’m looking for someone in the Easton, PA area that can install it. I’m pretty handy, but I would leave this one up to the professionals as it is winter season and I can’t afford to have no heat. I don’t know if I should wait until the winter is over or get it installed now, but the new one is just sitting there waiting. If you know of anyone give them my email or if anyone reads this that can do the job please contact me.
    The expansion tank is on the outlet side.
    I had read in a couple of places that clay tile was ok for gas.
Welcome
It looks like you're new here. Sign in or register to get started.
