Whistling Steam Radiator System
Michelle_9
Member Posts: 1
I've hear a lot about steam radiators making banging noises as but I have been unable to find anything on steam radiators that whistle in the night.
My landlord says there's nothing that can be done about this. Has anyone come across this before?
Copper Tube
If you have single pipe steam, the problem could be that the radaitor vents are whistling when the boiler shuts off, the steam condenses, and air is drawn back into the system. Some brands of vents seem to be worse than others. I originally had Watts vents on my radiators and they almost screamed when the system went into vacuum. I cut some 3/8" long pieces of 1/2" copper tubing and placed over the little pip at the top of the vent. They fit loosely enough that they didn't interfere with venting, but disrupted the airflow enough thet the vents didn't whistle under vacuum.
I now have Heat Timer Varivalves and Hoffman vents on the bedroom radiators . . . a little more expensive but much quieter.0 -
Happens to Me
Sometimes the vents whoosh when the boiler turns off, and it is definately from air being sucked into the vent. I have Gorton 6 valves. I assume this is normal and not a malfunction of the system.0 -
vents
The fix is usually new and working main vents, all the air shouldn't be coming into the rads, only the riser and rad volume.0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
