2 apt 1 thermostat
Hot water or steam heat?
Steve from Denver, CO
  • flash_3
    flash_3 Member Posts: 1
    2 apt & 1 thermostat
    i have a 2 family home 1 over 1. i have one oil furnance that heats both apartments using a 1-pipe steam systems.
    i control the thermostat for heating both apts. how do i allow the other apt to control the heat in their ap??
  • John@Reliable_14
    John@Reliable_14 Member Posts: 171
    how do i allow the other apt to control the heat in their apt??
    no easy way. 1) New system for them. 2) Steam zone valves one for you one for them (costly and inefficient. 3) And the biggest bang for you dollar proper venting. Someone that understands steam heat can vent the system radiators and piping so that every room will be the same/close temp throughout the house.
  • David Nadle
    David Nadle Member Posts: 624
    What kind of control?
    If the issue is a difference of opinion on what's a comfortable thermostat setting, there's no easy way.
    If the problem is the other apartment is regularly cooler than the thermostat setting, you can change the venting of the radiators to provide a better balance. If the other apartment is regularly too warm, you can try smaller vents or also install thermostatic radiator vents.
  • Steve Garson_2
    Steve Garson_2 Member Posts: 712
    Put a thermostat that cannot be tampered with in the cooler of the two apartments after confirming that your mains are well vented. Put slower venting vents and/or TRVs in the warmer apartment.
