InFloor plastic manifold
Scott Schneider
Member Posts: 2
John,
Thank you for the file it is greatly appreciated. Mark, Thank you for your reply and suggestion also.
Scott
Scott
I have run across a radiant floor system as manufactured by InFloor of Colorado. Besides the original installation having only 1 circulator and 4 zone valves the system works. I had 1 zone that was airbound so we installed a T and bled it off, now working ok. My question is there is a plastic manifold with dials to set the loop gpm, there is no writing on the dials, do you turn this CW or CCW to increase / decrease flow. Can anyone shine a light.0 -
Try
measuring the flow with a thermometer.0 -
Infloor Manifold Adjustment
Here is a diagram from an Infloor installation manual. Hope this helps. The tube lengths are for 3/8" and 1/2" PEX. The first number is for 3/8" and the second is for 1/2".0 -
infloor
Good luck on the adjustment area rep told me if i have a job with the plastic man and do any adjusting it will probabaly start to leak. So be prepaired for replacing.0
- 86.8K THE MAIN WALL
- 56 Biomass
- 108 Chimneys & Flues
- 5.6K Gas Heating
- 105 Geothermal
- 69 Pipe Deterioration
- 958 Plumbing
- 6.3K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
