vent
Harv_3
Member Posts: 6
Is this system vented enough?
Two mains one 49' with 3 gorton #1 on a tee, one 33' with 2 gorton #1 on a tee.
The outside diameter of the pipe is 7.5 inches, I believe that to be a 2" main?
Your thought are appreciated
Its a one pipe system.
Vents
If you mean 7 inches circumference, then it's a 2-in diameter main, and yes, sounds like you have adequate venting.0
- 86.8K THE MAIN WALL
- 56 Biomass
- 108 Chimneys & Flues
- 5.6K Gas Heating
- 105 Geothermal
- 69 Pipe Deterioration
- 959 Plumbing
- 6.3K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
