Actual HP vs Theoretical HP per Ton vs Evaporator Capacity.
DG4585
Member Posts: 2
Thankyou for the suggestion, appreciated!
Help
Does anyone have some insight to help me in the right direction? Ihave been racking my brain trying to find the mathematical relationship between Actual Horse Power, Theoretical Horse Power per ton, and Evaporator Capacity for a system. If anyone can help give me some clues to put me in the right direction, it would be appreciated.0 -
Find yourself
a copy of the "Trane Air Conditioning Manual" read chapter six and do the problems at the end of the chapter. It will take some effort but you won't be sorry. ...bobThere was an error rendering this rich post.
The old \" Blue Book \"
Man what a great book. I have a 1967 edition at home and a 1975 edition in the truck ( I can't see any difference ).0 -
You
You are here.Now scroll down to asked the professor and then
we will help.
This area is for wetheads only.
Come on down and take a journey with us and we will explain all about mass flow rate and heat of work.
Buckle up.
Rules of thumb
1 hp air cooled will yield/
1 ton @ high temp. AC range/
.75 ton @ medium temp. Cooler range/
.5 ton @ low temp. Freezer range/
Add a cooling tower and you can halv the hp0
