I need a quick Math Check...
Can someone please check my math...
I am working on venting a 1 pipe steam system with 58.5' of 2" and 17.8' of 1 1/4" main and am only coming up with 1.52 ft3 of air to vent. It seems low to me.
Here is how I am calculating it...
(58.5 x .023) + (17.8 x .01) = 1.3455 + .178 = 1.5235
Thanks.
Jeff
Welcome
It looks like you're new here. Sign in or register to get started.
  • Bob D._2
    Bob D._2 Member Posts: 34
    Volume check
    Close enough. Depends on your materials & fittings, but STD weight steel pipe works out to 1.55 cu. ft. (give or take).
  • Brad White_203
    Brad White_203 Member Posts: 506
    I get
    1.54817 cubic feet.
    More or less :)
  • scott k_3
    scott k_3 Member Posts: 22
    less
    Ok I vote for less. I get 1.427 ft^3. I assumed the diameter is ID (conservative) and assumed at atmospheric pressure. here's the math:
    vol=(pi)*radius^2*length soooooo for the 2"
    (3.14159)*0.0833^2*58.5=1.275ft^3
    for the 1.25"
    (3.14159)*0.05208^2*17.8'=0.152 ft^3
    for a grand total of 1.427 (actually less as there is wall thickness.)
  • Bill_111
    Bill_111 Member Posts: 3
    Correct
    1.4266 Cu. Ft.
Welcome
