The effects of glycol on a closed loop system
Timco
Member Posts: 3,040
Without getting into the whole pro-press thing, how does one stop the "blue spots" from forming on systems with glycol? It seems to not be leaking, but there they are. Is there a vent capable of handling glycol better? How does it act in the HX compared to water? Is there a less corrosive alternative? Saline solution? Seems there have been a few comments against the stuff, but seems like putting up with some blue spots is cheaper than the frozen loops in the other thread...
Tim
Tim
Well...
it's more expensive, harder to pump and thermally, less efficient than plain water - plus it's messy when you have to open the system for service - but up here in The Great White North - if you even think it might freeze - put it in.0 -
It's sneaky stuff
and seems to "blue out" even the tightest of threaded joints. Not a lot of options. Stay a way from threaded joints, although even the ball valve assembly joints sometimes "blue."
I did see a company manufacturing Corn Glycol, corn based instead of oil based. i'm not sure it would be less leak prone?
Dow builds a product called Slytherm (sp). I've seen it used in some solar systems. Very expensive but doesn't seem to have the seep issues. I have 55 used gallons if you want to experiment
We used glycerin in PVC fire sprinkler systems for years. It's very thick when cold and takes a gear pump to even shove it in a system if it is cold. Talk about a messy fluid to clean after a spill or leak!
I've heard one solar company talk about trying glycerin for a solar fluid. It may work as the panel gets warm before the circ starts?
hrBob "hot rod" Rohr
Living the hydronic dream0 -
Forgive the question, but why not alcohol?
TimJust a guy running some pipes.0 -
a bit flammable
but the geo folks have used it for years.
Our good friend larry has Vodka in his solar loop. if times get real tough....
Hydronic Antifreeze
Reading the list of things that could be used as antifreeze in a hyronic heating system made me think of the things that need to be of concern when choosing an fluid. Here are a few.
- Fluids that go BOOM when used around spark or flame.
- Fluids that corrode or eat away the system components.
- Fluids components that are not listed by the FDA as non-toxic.
- Fluid viscosity
- Fluid heat transfer
Just some fluid for thought.
- 87K THE MAIN WALL
- 57 Biomass
- 115 Chimneys & Flues
- 5.7K Gas Heating
- 106 Geothermal
- 70 Pipe Deterioration
- 983 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
