Viesmann Vitogas 100 constant circulation
Paul Pollets
Paul Pollets Member Posts: 3,663
Sorry, geriatric moment. The Vitotronic 200 does constant circulation of the pumps. They will shut off when the OD setpoint is above WWSD. Or to exercise. Both the A & B (mixing valve)circuits work the same way. I use the timer for radiators when using the A circuit, but rarely use the timer with the B circuit. I set the heating curves as low as can be, and still keep the areas at 68. We now install Vitodens instead of the Vitogas, except on very rare occaisions.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=104&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • jim_51
    jim_51 Member Posts: 69
    Constant Circulation on Viesmann Vitogas 100
    I am getting temperature swings in some rooms. I have a Vitogas 100 with a vitotronic 200 control panel. 2 zones. Would I be better off going with Constant Circulation. If so what is the best way to monitor? Should I just increase the settings on the two thermostats so circulators run all the time and turn down the Curve setting and monitor temperature? Please offer suggestions.
    Thanks for your help.
  • Paul Pollets
    Explain...
    How did you get the Vitotronic 200 control to integrate with the Vitodens 100? Do you mean you used an HK-1 mixing station with the V-100?
  • jim_51
    vitogas
    Paul
    The boiler is a vitogas 100 not a vitodens. I am not sure I understand your message.
  • jim_51
    vitogas 100
    Thanks for your help Paul
