Variable input gas burners?
just figured it had crossed enough eyes with no answer to indicate there's nothing out there plus I know of nothing and my search revealed nothing. Unfortunately the low end on the XM4 is about the top end of what I need. Anything smaller? I'm trying to retro an old gravity boiler in a modern fashion without replacing it if I can.
Powered variety?
Any out there, even just two stage or something?0 -
Guess not,,,
Eh?
Search finds nothing. Oh well, good idea while it lasted.0 -
Power Flame
has a burner which modulates I am not at location that I have the number but will get back to you.0 -
Patience MPF
we do not sit with baited breath waiting for the next question to be asked.
The Power Flame Burner is the X4M with capacity from 90,000 to 725,000 BTU's.
Web site www.powerflame.com0 -
What are you looking
to do if I know that I may be able to suggest something?0 -
Simul-click!
I just edited last post with that.0 -
Redo...
I'm trying to retro an old gravity boiler in a modern fashion without replacing it if I can.0 -
Why not any of the standard
conversion burners such as Midco EC200 or Carlin EZ both good choices.0 -
Just thinking,,,
even if I can just get a low fire/high fire setting out of it I can squeak more efficiency out of it on low load days? Seems like a good idea but I could be wrong. I guess if I went with outdoor reset I might achieve the same end?0 -
I know of nothing below about 300mbh input that has mod or
2 stage firing.0 -
Powerflame X4M400 modulating 90mbh to 400 mbh
Smallest i have seen and surprising to me they are making one that small. Don't know if it's small enough for you but there it is. Tim0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 64 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
