Taco question,
a confirmed Taco products supporter, I like the LTR low-water cut off( got my first today).<BR>As I`m a firm believer in a LWCO on <i>every</i> boiler, not all jurisdictions recognize a (built-in pressure switch) like the TT Prestige.<BR>Can this be incorporated into an MCBA controller, or must the standard LTA be used?<BR><BR>Dave
  • Joe Mattiello
    Joe Mattiello Member Posts: 720
    I’m not familiar with the MCBA controller. Perhaps you can provide more information on that control, the boiler manufacturer, and boiler model?
    In general, the LTR can work with most boilers that use 24VAC (ie. gas). If there is an OEM wiring harness on the boiler that doesn’t use screw terminals, the installer may have to splice into the harness. Knowing more about the boiler and controls will help.
    Joe Mattiello
    Taco Comfort Solutions
