finding a radiant leak in concrete
Derheatmeister
Member Posts: 1,573
Thermal Camera works good also i use a Audio listening devise ,or a laser scanner from the auto parts store may work,and if you believe in it the well finding technic works to:
#1: Take two pens(I used the papermate) take the case only
#2 Take two pieces of wire (Approx 18") bend a 90 angle at approx the length of the pen chase 5 1/2"
#3 stick the wire into the pen case and hold the cases in your hands approx 4 to 6 inch apart..
#4 hold the pen cases steady and try finding a body of known water i.e. a well or toilet.. You will know it when you find it: the wires will cross.
Once you "mastered" the fine art of finding a body of water
try it on your radiant leak!
Some say it's: "Hokus pocus" but it has worked for me before with in 8" at 3 feet deep
Good luck..
Good luck..
has anyone had to find a leak in radiant tubing in 4" of concrete? (1/2" Viega hepex). I'm working on renting a thermal imaging camera, but seeing if there are any other options out there. The pressure seems to drop faster the hotter the tubing is0 -
Devining rod
Heatmiester, I have a friend that does that trick to find buried field tile in farm fields. He uses a couple of pieces of bent brazing rod and swears by it!0 -
I actually used the brazing rods a couple weeks ago to find my daughter's sewer line in her back yard. Approached it from several different angles and came up with the same spot. Dug down 3 feet and Viola, found the sewer line. I'm a believer.
Scott0 -
Damp Mop
Take a damp mop and mop the floor. You'll see the layout of the tubing as the floor dries, except where the leak is.0 -
For any Wallie, I'd be happy to UPS my cat to any address in the USA! She loves the warm spot at the leak! She finds it every time!0 -
Thermal Imaging Camera
Got a Volunteer Fire Dept in your area with one? For a small donation they might come out and assist you!! Be good to the Vollies its all some of us have.0 -
Cats know0 -
or , get a dog
Adopt a dog from the shelter. With a day or two, dog will lay down on the spot..0
- 86K THE MAIN WALL
- 52 Biomass
- 421 Carbon Monoxide Awareness
- 81 Chimneys & Flues
- 5.3K Gas Heating
- 96 Geothermal
- 154 Indoor-Air Quality
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 893 Plumbing
- 5.9K Radiant Heating
- 379 Solar
- 14.7K Strictly Steam
- 52 Water Quality
- 41 Industry Classes
