Geothermal Equipment
Just curious what brands you guys use and like. We have been looking closely @ Water Furnace & Florida Heat-Pump.
  • Mark Custis
    Mark Custis Member Posts: 537
    Look at
    Heatcontroller and their configurations vs Waterfurnace and Florida. The boxes look like they came out of Jackson MI, only the control boards know for sure.
    I use Heat Controllers Comfort Maker stuff, for the most part their tech crew uses pump and dump, but I install it closed system. Their integrated controls and sensors are good. You need to read the instructions.
    You need to know all about moving water to make the best system.
  • joel_19
    joel_19 Member Posts: 933
    well first.....
    what type of system do you want to do
    direct ground exchange (refridgerant in ground loops)?
    standing colum water well.?
    Loop well with glycol.?
    slinky or loop in ground?
  • klaus
    klaus Member Posts: 183
    GSHP's
    I've installed a few Hydron Module's and been very impressed. They seem to be a well thought out machine. I like the fit and finish right down to the case (stainless steel). They have models that do combination hydronic and forced air also.
    For larger commercial jobs we've done Climate Master and Water Furnace. I personally like the CM a little better.
  • Jamie Pompetti_2
    Jamie Pompetti_2 Member Posts: 62
    Joel,
    We are doing a 5 ton closed loop system with two vertical bores at 465'! We will have a glcol mix in the loops. It's for a commercial building that will have four forced air zones. It's our first LEED project also....
    Jamie
  • Mark Eatherton
    Mark Eatherton Member Posts: 5,874
    I'm looking at Mitsubishi...
    They have a feature that others OUGHT to have, but still don't, that feature being variable speed.
    They've just recently come out with a GSHP version. I'm actually looking forward to applying their inverter technology on my next GSHP application.
    We've lost over half of the compressors in our GSHP installations (WFI)...
    http://www.mitsubishi-aircon.co.uk/default.asp?url=http://www.mitsubishi-aircon.co.uk/mitsubishi_electric.asp?id=155366
    ME
  • Mark Custis
    Five tons
    per zone?
  • Only have one in
    So I really cant compare. I installed a ClimateMaster water to water in my own home, 3 ton pump and dump. Works great so far. The unit is factory sealed no vac, no brazing. I did drop a new Franklin constant pressure pump down the well first and did a draindown line with a vac breaker to the pipe to the creek,I used a 40 gallon solar tank as a buffer, probably the easiest boiler I ever put in.
    TONY
  • Blackoakbob
    Blackoakbob Member Posts: 252
    geo brand
    I have used Waterfurnace the last couple times, but other brands since 1979. The last two were my first closed loop and have been working very well. Interconnecting with utility programs has been a tough, as no one company has a control and the utility programs are not all the same. They are required to offer conservation programs by the state public utility commission (MN) but not required to make it easy to deal with. All in all the gshp systems hve been much more reliable than in past years. Best regards
  • GREG LAUER
    GREG LAUER Member Posts: 103
    hold on
    stay away from florida heat pump may problems. why go geo when you can go Daikin and drop the cost of wells and run at a higher eff?
  • joel_19
    Mitsubishi
    that link is UK right? do they have a US version available???
  • Riverrat35
    Riverrat35 Member Posts: 16
    daikin
    can you make heat with a daikin
  • GREG LAUER
    heat with Daikin
    who cares? the geo only heats hot water when the unit is running there is no dhw call for heat that brings the unit on so on a mild day it does nothing and with a 15% savings over geothermal (without figuring in the well cost)buy a high eff water heater if it is a big deal. big things are on the way from Daikin
  • Tony_42
    Tony_42 Member Posts: 37
    Check this out from REHAU-RAUGEO
    REHAU left the plumbing business because plumbing pex is a commodity that's in a race to the bottom. REHAU is focusing on low temp radiant floor heating, radiant cooling, solar and geothermal. Their vision is 20 years down the road...
  • carter_3
    carter_3 Member Posts: 23
    Geothermal
    Check out Econar
  • Mark Custis
    Rick
    Watch them grow
    They are the leading edge. They thought they wanted to sue me for building a radiant floor in a pond. I use it for a water to water system.
    I will be puting loops in footers when possible.
  • Mark Eatherton
    Better link...
    http://www.mehvac.com/
    ME
