Sizing drop header
Steve Garson_6
Member Posts: 35
I am going to re-pipe some poorly installed steam piping off a boiler that burns 490,000 BTU/hour. The Smith boiler has two 3-inch risers.
My plan was to pipe the two 3-inch risers to loop down to a 4-inch pipe that would feed three risers to feed the three mains for the building. Will the 4-inch pipe be large enough? Larger is so much more expensive.
Suggestions?
Steve
Suggestions?
Steve
it would be sized
the same as called out in the manual for a standard header..i'm not sure what that would be for that brand..they probably have the manual online i would imagine.
steam drum
Some of hb smith boilers i have done in the past had oversized steam drums in lieu of a conventional header. check their piping diagrams. a steam drum is the ultimate header.0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 916 Plumbing
- 6K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
